1 - 9 of 9 Posts
Having one of those electrical gremlins issue. I got both a low and high beam Prolumen HID Kit.
It was fairly plug and play but it definitely not working properly.
With the ignition on, the low beam lights up but once I fire the engine and it's running, low beam goes off. With the engine running, I switch to high beam and that works. Try to switch back to low beam. No go.
Did I cross the wires, do I need resistors, I'm at a lost.
Any ideas or suggestions?
Electronic relays like for the turn signals? I know there is one right next to the battery.
Is there a particular relay I would need for the HID and at what point would I install the relay?
If I sound like I'm talking out of my ass,its probably cause I dont know too much electrical when it comes to relays, resistors, etc. :confused:
I would say you need relays for the two HIDs.
brian.
Indeed, the wiring on a 916 is not up to carrying the load.
I fitted a HID low beam to mine which needed a relay as voltage drop causes it to trip out especially if the light is on when starting the engine. I also fitted a relay for the main beam (100w halogen) which made it brighter and quicker on - even with a stock 55w bulb.
I fitted the relays by the battery using heavy gauge wiring from battery to relay to light, also fitted a separate heavy gauge negative from battery to light. Make sure you fit fuses to the relay supply.
The red piece with red cable is a fuse holder (clips into existing main fuse holder) which supplies the two (black) 12v automotive relays that in turn switch the lights using the lightswitch wiring to power the relays.
Im sure your answer is above, but Ill just give you my starting procedure. I bought my 2001 748 with a ghetto ridged low beam HID. In order to get it to stay on once the bike fires I have to turn the ignition on and let the ballast warm up and get to full power for a few seconds before I fire the bike. Maybe I could benefit from a relay as well??? I know very little about electrical except it can hurt. :eek:
Discussion Starter · #8 ·
Dang.. guess that's part of the joy of owing a 916.
Wished it would have been made known that relays were needed for HID kits for the 916.
Most write-ups just described how to install the kits and not too much mentioned on the relays.
Guess I will have to monkey around with the electrical some more.... oh joooooy. :rolleyes:
1 - 9 of 9 Posts
