Yeah, I second this, esp if the starter didn't even try. Use a tie wrap around the solenoid and between the two wires to keep it on. Mine will wiggle out over time otherwise.Check the white two-wire plug in the starter solenoid, these have a habit of falling out... just had a moment with mine not starting - one of the connectors in said plug had pulled out the back of it?![]()
+3Yeah, I second this, esp if the starter didn't even try. Use a tie wrap around the solenoid and between the two wires to keep it on. Mine will wiggle out over time otherwise.
That plug can be impossible to get to. Here's what i did:Little plug was ziptied in ages ago - still in place?
Good shout!That plug can be impossible to get to. Here's what i did:
Knowing that even though my solenoid was still good, I decided to replace it with a Yamaha unit that has a pigtail female plug, kinda like this one:
Solenoid
Then I bought a simple waterproof 2-wire connector like this one:
Connector
Fitted it all up, and now I have a new starter solenoid with a long pigtail and a new connector, all for about 30 bucks. Well worth the piece of mind.
