A quick, initial go-through revealed the following:
Cleaning the tank and replacing the pump
I pulled the tank off and drained the gas. Well, the liquid. At least 100-150ml were actually dirty/rusty water. Which let me to quickly discover that the tank was quite rusty on the inside. No idea why I did not see that when I checked inside the tank when I bought the bike. Oh well...
I removed the gas cap and pulled the pump, oil filter and sock sieve out - indeed dead. I ordered the replacement part via Stein Dinse.
For rust removal I used Rostio cleaner and passifier:
Rostio Tankentroster 1 Liter plus Tank - Schutzemulsion | Tanksanierung | Rostio Rostumwandler & Rostentferner Online Shop - Rost entfernen leicht gemacht
The cleaner is acid based (I suspect citric acid or similar) and is filled into the tank hot (I topped off with close to boiling water), then left sitting for enough time to dissolve all the iron oxide. I left mine for a bit more than 24h, I believe. The used cleaner solution is drained, the tank rinsed with water (I used deionized water) and immediately rinsed with the passifying emulsion. I don't know what it contains but suspect maybe a phosphating agent? In any case: the tank does NOT have to be dried to apply the emulsion. This simplifies matters considerably. I specifically decided for Rostio for that reason: too many horror stories where a polymer based coating either does not stick for long, or sticks too well, or... I reasoned that in the worst case, I could repeat the operation and use a different, polymer based coat. So far, there is absolutely no new rust present.
Gas cap reinstall
The new pump installed easily. Biggest issue was to replace the old, hardened fuel lines inside the tank with new, fuel resistant lines. However, when trying to re-install the gas cap, I was unable to get it to fit - lubricants, mild force, cursing, all didn't make a difference. Since the green inner O-ring was having a bit of a loose fit, I suspected that it was preventing the cap from seating and ordered a new one. Of course I could not wait and tried some more - only to find out that I had installed the top (black) gasket upside-down. If it is that way, one will not be able to install the gas cap. Bugger...
I had mentioned above, that the seller had alerted me to the fact that he broke off the turn signal stalk. Well, I mainly learn from my own mistakes, so I broke it off, too. (if the front wheel is turned to the left and one, like me, is not careful when closing the tank, it will come in contact with the indicator stalk and snap it off...) I'll talk about how I repaired it later.
With the pump in again, I re-installed the tank and started her up successfully and took her for a spin: she ran OK except that at high revs she seemed not to be getting enough gas. All OK at lower revs, though. I also barely made it home before the battery was dead.
So two new issues found:
Incorrectly installed tank check valve
The fueling at high revs may have been due to the tank check valve (one-way valve; the small aluminum cylinder in the fuel vent line from the top of the tank to the steering stem). It was installed the wrong way round - it would let fuel vapour pressure exit the tank but not replenish dropping pressure due to fuel consumption. There is a small arrow on the cylinder that has to point away from the tank. Also check if you can blow air through in the direction of the arrow. If you can, the valve is broken. If you cannot blow air through in the other direction, the valve may be plugged or broken. There are multiple posts here that discuss the issue.
I am not sure if this was the actual problem here - the non-functioning charging system and associated discharged battery could likely have caused similar problems.
Replacing dead idiot lights
With the fairing completely removed, access to the lower part of the iinstrument cluster is easy. Two small screws and the idiot light holder comes out. The small, 1.2W bulbs (2721-02B; 286 capless) themselves have to be pulled up and out - the holder they are in stays in place. Be careful not to damage the latter - it appears to be unavailable these days. Bulbs cost next to nothing at your local auto store.
I reinstalled the panel and the side stand light was not working, state of the low fuel sensor unknown (turned out to be OK after I used enough fuel at a later stage), an intermittent neutral light and the engine light not coming on with ignition on.
Charging system
As mentioned, I found out on my first test ride that the battery was not getting charged.
It boils down to: the installed aftermarket regulator / rectifier was shot - delivered only battery voltage no matter how high the revs. Alternator and all fuses checked out OK. I bought a new RR and it did not work either initially - due to a bad earth, as I found out after a while and helpful comments from forum members.
The whole story is here:
(3) 900SS 93 charging problems | Ducati.ms - The Ultimate Ducati Forum
Thanks to all that helped me work through this.
Sidestand warning light / switch
Since the side stand warning light did not work I checked out the switch. It turned out to be stuck in the "up" position. The connection from the cables to the switch was visibly damaged and when I removed the switch, water ran out of the black cable sleeve. Apparently the previous owner kept the bike clean by regularly treating it to a pressure wash...
I bought a new switch off Stein Dinse - hideously expensive at about 60EUR :-( If anybody knows about a less expensive aftermarket option, I'd be very happy if they could post it here. The design of the sidestand switch (and the neutral switch) is such that I expect that they will fail in the not too far future again. And yes: I could live without these but would really like the bike to be complete and close to stock (or easily be brought back to it).
- dead fuel pump
- non-original bolts of different size holding the side stand
- some idiot lights not running (side stand, charging system, neutral intermittent)
- additional Veglia T gauge
- headlight gasket incorrectly installed
Gas cap reinstall
- fueling at high revs
- charging system not running properly
Charging system
