Just posting this here again, in case it was missed in the Intro / Welcome forum ...
It looks as if i need a(nother) new battery. Before I buy the usual lead-acid Yuasa YB16AL(?) solution, is there a more modern / high-tech solution that would be recommended?
I noticed at the IMOT motorcycle show that there were several companies selling alternative battery solutions e.g. a firm called CS-Batteries (CS-Batteries.com; LiFePO;Starterbatterien;Motorrad;Batterien;) have a LiFePo unit that is claimed to be easy to install and better in every way ...
Any thoughts?
It was also suggested to stick with a gel (?) battery and update the ignition system instead ... open to your thoughs there too!
Robb.
Any thoughts?
Robb.
