Thanks very much. Just what I was looking for.
Is there an easy way to remove and replace the steering stem lower bearing?
Just finished this job on my 1995 900ss, similar tapered roller bearing. My steps were...
- Remove the cage and rollers with snips and something to pry with, a common screwdriver works. It’s not pretty but it works.
- Use a Dremel tool with a small cut off disc to cut a notch in the remaining inner race. Cut as deep as you can without damaging the steering head.
- Split the inner race with a screwdriver or chisel in the notch you just cut. Once split it can be removed by hand and used as a drift to safely install the fresh bearing.
Hope that helps
Cheers
