I'm coming up on 18k miles on my '04 ST4S, and have a couple questions about the valve check.
A little history: I purchased the bike with just under 12k miles, and immediately prior to selling the bike, the previous owner had the 12k service performed at a dealer. Fortunately, I have the paperwork, which indicates the valves were adjusted, rocker arms checked, it got new belts and spark plugs. It doesn't look like any rockers were replaced, and there are no specifics regarding the valve adjustment.
Anyway, on to the questions:
First, I'm planning on doing the work myself, and I have LT's book, and have read much on the forums regarding the process. What I haven't been able to find is if it's possible to check the clearances without removing the belts? I would like to avoid unnecessary effort if the valves are in spec, so is it possible to check clearances without removing the belts? Also, what is the likelihood of the valves being in spec?
Second, are there any special tools that are absolutely necessary? Time and funds are a little limited as I have a trip coming up, so I'm trying to be frugal with both.
Thanks!
Thanks!
