Where is the best place to buy one? and does anyone know part #'s for jt sprocket or someone like that?
Dont have a local dealer... AMS is the closest and they are about 4 hours away. Looking for an online vendor.Around $40 from your dealer. You'll need a good 1/2" impact gun to remove the nut. Be warned, it can a bitch to break loose. A LITTLE heat on the nut only with a low propane flame makes it a lot eaiser. Loosen the chain(no need for removal) and remove the covers, no problem. Loctite on assy.
And don't forget the lock washer!!!!!Around $40 from your dealer. You'll need a good 1/2" impact gun to remove the nut. Be warned, it can a bitch to break loose. A LITTLE heat on the nut only with a low propane flame makes it a lot eaiser. Loosen the chain(no need for removal) and remove the covers, no problem. Loctite on assy.
