G'day all,
I did a long ride today, and when I got to about 10km from home my bike lost it's mind a little... I have no idea what's caused it, but it seemed to occur just a few seconds after I swapped from Sport, to Touring mode (whilst on the move). Basically the "DTC OFF" caution sign came on, along with the EOBD/ABS lights. Rest of the problems as below...
Symptoms:
- Error for messages "ABS" & "Speed Sensor"
- "DTC OFF" warning triangle
- Bike electrics will not turn off with the handlebar switch like normal. I can turn the engine off, but the usual button does nothing to turn off the fan/dash/electrics
- Only way to turn the bike off is with the button in front of the tank under the little cover
- Otherwise seems to be running and functioning as normal
What I've checked/tried:
- Turning it off/on, starting it/stopping it, changing riding modes, disconnecting the battery
- Both front and rear ABS sensors. Both seem fine, and I've cleaned them off - no fix...
- EVERY fuse. Not just for the ABS, but for everything - no blows anywhere
- ABS sensor connections for the front under the beak, and the rear under the riders seat. Both seemed fine externally.
Does anyone have ANY idea what the hell might be going on here? I am at a total loss. I've read some things about the sensor wires snapping on both the front and the rear, anyone know a way to check if that's occurred short of taking off the whole wire? I'd read something about checking the resistance, but haven't done that as yet because my multimeter seems to have given up the ghost too!
If anyone has seen something like this before, or can point me in the direction of some more things to fault find it would be a huge help!
Italian Electronics
Cheers,
Tom
Symptoms:
Italian Electronics
Cheers,
Tom
