1 - 20 of 20 Posts
Has anyone pulled off the hand guards
Just need to know where the wire plugs into the loom
Hard to follow with all the body panels on the bike
Do I have to pull the tank to get to ?
Discussion Starter #2
Got it
Just don’t want the hand shields on the bike
Will do a different signal set up
Still in the works
Really like to see what you come up with ebrew. Been exploring ideas to do the same but haven't come up with a neat looking solution for the turn signals
How about these from Rizoma? :
Screenshot from 2019-11-03 22:15:58.png
I will post the solution when done :)
It’s going to be cool I hope
This was my solution, i also added a very bright blinkers on the bottom of the nose panels.
(Just to throw another idea in the pool)
Discussion Starter #7
Nice looks great
I’m adding some small driving lights that have turn signal halos built into them
Hope to have the lights soon
Very compact lights 2”x2” so not big adv lights
Got a cool billet mount ( still need to drill )
And just found a cool switch mount as well sits next to the grip and hangs under right next to your thumb
This is a very interesting thread for me. It's not because I don't like the hand guard because I do.
What I don't like is that the reservoirs are attached to them. If you damage the plastic hand guards, your reservoir will likely dangle.
Got it
Still in the works View attachment 975654
What reservoir mounts are these? These are exactly what I've been looking for. I cut my handguards and installed bar end mirrors. But I spent a little time with the dremel and made the plastic factory handguard reservoir mounts look pretty decent. But it's always been a short term solution until I found some aluminum ones.
Discussion Starter #10
They are off a hyper ( Ducati OE parts )
Get the mounting bolts too
Was a new bike on the floor so I’m assuming 2019. My parts guy ordered them
I picked up the Panigale Reservoir mounts 8291A701AA and 8291A691AA. The Hyper ones look like they are a bit higher though, might be better option. I do Like the Fork mount bracket.
Discussion Starter #12
So might set the driving lights up to come on with the high beams
Anyone done this and if so where did you tap the power ( what wire is high beam )
Discussion Starter #13
Next step :)
Just the right size
The orange rings on the lights will be the new turn signals
Wiring next. Will run into OE harness for signals and I hope OE hook up for Ducati driving lights ( I have the OE harness ) it’s a three wire not sure why it’s three wire and not two
Working on that part
Ebrew, as you discovered where the turn signals plug in, can you share before I start pulling off panels? Are they easy to get to?
Have you hooked up the spot lights directly to the battery or through some kind of a junction box? if the latter, any pointers /pictures are welcome.
1 - 20 of 20 Posts
