Got this 2013 1200S Touring with only 5500 miles from this older gentleman 3 weeks ago to ride with the wife or actually go somewhere as opposed to thrashing with the Hyper SP. after the test ride I noticed what could be a warped rotor but still buy after he reduced his price. Now I am half decent with a wrench since I roadraced for many years. After more riding I noticed that i don’t really feel this at the lever (abs?) and it’s just the top fairing and the gauges shaking up and down. I wanted to replace the worn stock tires with Power 3 so:
I removed the wheel and make sure all the rotors buttons were loose, I cleaned the rotors and pad with 3M, I cleaned the calipers and pistons and make sure they move freely. I inspected the rotors and they looked straight when turning. The bearings were hard to turn with my fingers so I thought I got it. I changed them with OEM parts. I checked for any play in head bearing and felt none. Reassemble everything and went to scrub the new tire. STILL does it! The weird thing is: if I got 100mph then brake its smooth, as my speed go through 65-55 it shakes hard then dramatically reduce below 50. If I brake at 40mph it’s barely noticeable. Light or hard braking doesn’t matter much.
I am stomped and since it doesn’t do it above 80 I am reluctant to buy new rotors. Any IDEA??
P.S. I need to change this old signature, these are ALL gone
Thanks
Thanks
