61 - 77 of 77 Posts
Discussion Starter #61
Ducati 1199 Panigale: CORSE DYNAMICS Adjustable Shift Linkage
Allows easy adjustment without removal of the shifter.
$59.95
CORSE DYNAMICS Adjustable Shift Linkage: Ducati 1199 Panigale
The factory shift rod on the Ducati Panigale is right hand thread on both sides preventing adjustment without fully removing the linkage from the bike. The Corse Dynamics kit includes a new adjuster rod that allows for adjustment on the bike with simple tools.
Kit Includes:
-Aluminum adjuster rod (right hand thread on one side, left hand thread on one side)
-Left hand threaded heim joint
-Left hand threaded jam nut
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
Discussion Starter #62
Ducati 1199 Panigale: RIZOMA Billet Aluminum
RIZOMA Billet Aluminum Fuel Cap: 1199 Panigale / Streetfighter
$208.00
These custom fuel filler caps come with a special Rizoma key for added safety and ease of use. Rizoma consistently produces the highest quality Italian accessories. Comes with everything required and is an easy install. Available in Black or Silver finish.
RIZOMA Clutch Cover Protection: 1199 Panigale
$159.00
CNC machined billet and hard anodized engine clutch covers for the Ducati Panigale. Beautiful anodizing and protective slider material make these 1199 clutch covers standout and provide the added protection while adding an understated elegance to your bike.
RIZOMA Engine Oil Filler Cap: 1199 Panigale / 848 / MTS1200 / M696 / HM 796 / D16RR / Diavel
$60.00
These uniquely useful caps are made of billet aluminum are an extremely easy install. Universal sizes and threads to match most bikes.
Simply the most beautifully designed and elegant oil filler caps out there and the finish is truly impeccable. A quick and easy way to dress up your bike. It's the little things that make your bike stand out. Includes a removable plate with a wire locking tab for lock wiring use on track days (a mandatory requirement), or just for added security.
RIZOMA Fluid Reservoir Bracket - 1199 Panigale
$48.00
Rizoma billet fluid tank bracket specifically designed for the Ducati 1199 Panigale. This bracket works with all Rizoma fluid tanks besides the CT015 and CT017. Sold individually. This mounting bracket is required to mount any of the Rizoma Clutch or Front Brake Fluid Tanks.
RIZOMA FOX License Plate Kit: 1199 Panigale
$245.00
RIZOMA license plate holders are designed exclusively with high quality aerospace alloys for structural strength and reliability in a small form factor. With a range of angle and extension adjustments, they are equipped with a reflector and the latest SMD LED lights, for full compliance with legal requirements.
RIZOMA Frame Plug Kit: 1199 Panigale
$122.00
Rizoma frame hole cap kit includes a total of (4) frame hole covers for your Ducati 1199.
RIZOMA Front Axle Slider: 1199 Panigale
$97.00
RIZOMA guards are designed to protect the fork and swing arm in case of falls, preventing them from scraping on the ground and softening impact stress. Their elegant design adds to the overall style of your bike.
RIZOMA Next Fluid Reservoir Kit - 1199 Panigale
$290.00
These fluid tank represent a new and absolutely unconventional line, which re-interprets a purely functional concept of this element and turns it into a distinct object.
Discussion Starter #63
Ducati 1199 / MTS 1200 / Diavel: EVR Ducati Wet Slipper Clutch
EVR Ducati Wet Slipper Clutch: 1199 Panigale / MTS 1200 / Diavel
$1,050.00 FREE Shipping
EVR Ducati slipper clutch eliminates rear wheel chatter on corner entry improving stability and ultimately lap times on the track as well as improving safety on the street. Retains OEM clutch plates and basket. To fit Ducati 1199 Panigale, Multistrada 1200, and Diavel. EVR slipper clutches use a patented technology that greatly improves operation and clutch life when compared to the competition.
Discussion Starter #64
1199 Panigale: Ducabike Top Triple Clamp
Ducabike Top Triple Clamp : 1199 Panigale
Was:$279.99
Sale:$249.99
Moto GP inspired. Improves the stiffness of the front end. Direct bolt on. Made from 7075 Billet Aluminum.
Discussion Starter #65
CORSE DYNAMICS Ride Height Tool: Ducati 1199/S/R Panigale
Measure ride height with ease and 100% accuracy everytime. We now have a bushing that will fitment to the 1199R...
CORSE DYNAMICS Ride Height Tool: Ducati 1199 Panigale
Pricing:$69.95
With adjustable linkage featured on the 1199 comes the need to keep track of ride height, ride height controls every aspect of handling and is crucial in being maintained. This tool easily slides into the frame on the left hand side for consistent measurements everytime.
*Will not work with DP rearsets as the frame support is changed on these rearsets
If you have an 1199R you will need to purchase this tool as well as the following bushing:
CORSE DYNAMICS Ride Height Tool Adapter: Ducati 1199R Panigale
Made in the United States of America
Discussion Starter #66
Ducati 1199 Panigale: MW Tuning Kickstand Bypass
MW Tuning Kickstand Bypass: Ducati 1199 Panigale
$36.95
No more unreliable solutions, this is a direct plug into the harness and allows removal of the entire switch.
Utilizes OEM harness connector for ultra easy install and a weather proof cover for years of worry free operation.
Racers: check out the spacer kit that allows the removal of the kickstand mount to save over a pound of useless weight.
CORSE DYNAMICS Kickstand Delete Spacers: Ducati 1199 Panigale
Discussion Starter #67
Ducati 1199 Panigale: CORSE DYNAMICS Kickstand Delete Spacers
$29.95
Allows removal of complete kickstand mounting bracket instead of just unbolting the kickstand, saves weight and gives a finished appearance.
506 grams (stock mount and kickstand)
40 grams (replacement spacer kit)
SAVE over 1 lb. (466 grams) of unnecessary weight.
Includes 2 spacers (reuses OEM bolts)
This kit does not include a Kickstand Bypass, that must be purchased separately or bypassed electronically on your own
Discussion Starter #68
Ducati 1199 Panigale: LeoVince Carbon Fiber Alternator Cover
LeoVince Carbon Fiber Alternator Cover [12054]: Ducati 1199 Panigale
Was:$139.00
Sale:$113.98 FREE Shipping
High quality AMA homologated carbon fiber case cover
Mounts over existing OEM cover only
Provides increased protection and abrasion resistance
Discussion Starter #69
Ducati 1199 Panigale: LeoVince Carbon Fiber Clutch Cover
LeoVince Carbon Fiber Clutch Cover [12053]: Ducati 1199 Panigale
Was:$139.00
Discussion Starter #70
Ducati 1199 Panigale: BREMBO HPK Disk Kit [Ducati 5 Bolt 15MM Offset]
Brembo rotors designed specifcally for the Ducati 1199 Panigale.
BREMBO HPK Disk Kit [Ducati 5 Bolt 15MM Offset] - 1199 Panigale - 330mm diameter
$735.00/ set FREE Shipping
World Supersport winning rotors for the street. These fully homologated for the street rotors have performed at the highest level in World Supersport and dominated the class outperforming any other competitors rotor on many occasions.
330mm diameter
• Stainless Steel
• 5.5mm thickness with a 34mm wide friction surface
• CNC machined aluminum carrier
• Compatible with the ABS / DTC flying wheel
Discussion Starter #71
NEW! 1199 Panigale Integrated Turn signal/Tail Light
In stock!
Competition Werkes Integrated Tail Light: 1199
$234.95 FREE shipping
Complete replacement taillight assembly with running light, brake light and integrated turn signals.
All factory connectors (no wire splicing).
Turn signals flash amber and at a factory rate.
Brake light and taillight are DOT compliant.
Discussion Starter #73
Ducati 1199 Panigale R Tail Sticker Kit
$24.95
Ducati 1199 Panigale R Tail Stickers (6 Pc)
*Also available:
Ducati Corse 1199 Panigale R Sticker
Ducati 1199 Panigale R Nose Sticker Kit
Ducati 1199 Panigale R Nose Sticker Kit: Solid
Discussion Starter #74
Ducati 1199 Panigale Nose Sticker Kit
$17.95
Ducati 1199 Panigale R Nose Fairing Stickers with "Ducati" logo (2 Pc.)
Each sticker 10" x 3.5"
$17.95
Ducati 1199 Panigale R Nose Fairing Stickers (2 Pc.) without the "DUCATI" in the right sticker. This for the 1199 and 1199S which already has the DUCATI logo on the OEM nose fairing.
*Also available:
Discussion Starter #75
NEW! CDT CF Kick Stand: 1199 Panigale
$407.95 FREE Shipping
CDT Elite Series Carbon Fiber by CDT is light, strong and flexible. They manufacture using the same raw materials and production processes as MotoGP, World Superbike, Ducati Factory and Formula 1 bodywork.
CDT Carbon Fiber begins with pre-impregnated carbon fiber ("pre-preg carbon") which is carbon fiber fabric that is saturated with a precise amount of epoxy resin and must be carefully stored in sub-zero temperatures. Pre-preg carbon is stronger, lighter and more consistent than non-pre-preg carbon fabric (which has resin applied during the production process). To create bodywork, the pre-preg carbon is vacuum-bagged, autoclaved and clear-coated. The vacuum-bagging process uses suction to make the pre-preg carbon conform exactly to the shape of a part mold. The molded part is placed in an autoclave (think of it as an industrial strength pressure cooker) and subjected to carefully calibrated heat and pressure to cure the part. The end result is a perfectly shaped carbon fiber part that uses an absolutely minimal amount of epoxy resin yet is superior to any other carbon fiber piece.
Finally, the part needs to be given a perfect finish. The part is magnetized, sprayed with clear-coat powder pellets and baked in oven. This causes the powder pellets to melt and penetrate the carbon fiber, allowing for a deep, smooth, pit-free, super-shiny finish.
Discussion Starter #76
Ducati 1199 Panigale: OBERON Clutch Slave Cylinder
OBERON Clutch Slave Cylinder: Ducati 1199 Panigale
Pricing: $153.00 FREE Shipping
The Oberon Performance Ducati Panigale 1199 clutch slave cylinder has been designed to improve the efficiency and the looks of the original clutch slave cylinder unit. The internal piston design and seals have been drastically re-engineered to prevent leaks, piston jamming when hot and leave a smoother (judder free) clutch action. CNC machined from T6 billet alloy for lightness, strength and eye-catching good looks. Everything you need is included in the kit including full instructions and is ready to fit.
Our piston seals are manufactured from special Viton rubber which is frozen and then CNC machined with a 'U' profile (not standard 'O' rings) which is specifically for hydraulic use.
Weight: 104g
Anyone selling a lock set for a 1199, lost the only key I had, plus I have no code. Is it possible to buy a key from the dealer, getting it program, and get it cut?
61 - 77 of 77 Posts
