1 - 20 of 77 Posts
If you are interested in 1199 parts, watch this thread. We will be adding parts that we have fit tested on our 1199 Panigale as well as new parts that we are developing with other companies.
MW Billet Q/R Fuel Cap: Ducati 1199 Panigale
$149.99
This high quality fuel cap made of billet aluminum is made in Italy. This fuel cap is anodized black and includes all the mounting bolts you need and the breather tube comes pre-installed. Available in Black, Gold, or Silver.
Stock 1199 cap weight .8lb. This billet cap weigh .45lb.
CF Fuel Cap Quick Release: Ducati 1199 Panigale
Was:$179.99
Sale:$165.00
Carbon Fiber quick release fuel cap for the Ducati 1199 Panigale.
Stock 1199 cap weight .8lb. This carbon fiber/aluminum cap weigh .40lb.
OBERON Billet Foot Pegs: Ducati 1199 Panigale
Was:$54.95
Sale:$49.00
Pair of footpegs from Oberon. Each kit is a direct replacement for your original footpegs, you will need to re use your pin and spring assembly. Available in two different styles. Length of smaller peg (excluding hanger/fitment) is 80mm and width of peg is 19mm. Length of larger peg (excluding hanger/fitment) is 90mm and width of peg is 26mm. Installed overall length of OEM peg is 100mm, overall length of Oberon large peg is 120mm, overall length of Oberon small peg is 110mm.
Shorai Lithium Iron LiFePO4 Battery KIT: Ducati 1199 Panigale
$189.95
Installation requires using the included negative cable and raising the positive cable due to the Shorai battery being slightly taller. Also the OEM top battery bracket will not work and so we include a zip tie to secure the battery to the tray and some hardware to mount the top.
  • 18 Amp Hour, 270 Cold Cranking Amps.
  • Ultra-light weight - 2.19 lb.
  • Ultra-compact - 5.83” x 4.13” x 2.60”
  • Includes longer negative cable specifically for the Ducati 1199 Panigale
  • Weight savings over stock battery is 4.4 lbs and increases cranking power significantly. See video on our website to see the difference in starting.
http://motowheels.com/images/F46941722.jpg http://motowheels.com/images/F46941736.jpg
BST 7 Spoke Front Wheel: 1199 Panigale
Price: $1,845.00
Sale: $1,752.75
BST 7 Spoke Rear Wheel: 1199 Panigale
Price: $1,995
Sale: $1,895.25
BST rear wheel alone saves about 2 lbs over the very light OEM Ducati "chicken feet" Marchesini forged rear wheel.
Available at Motowheels in matte or gloss finish for the 1199.
CORSE DYNAMICS Eccentric Chain Tool: Large Axle
$28.95
Easy to use single sided swingarm adjustment tool for Ducati 1199 and all other Single Sided Large Axle Swingarms.
CNC machined for optimum fit and handle comfort, no slip style featuring 4 seperate faces contacting the eccentric spanner nut
* FREE shipping on orders over $100
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best.
Discussion Starter #2 (Edited)
1199 Parts
RHINOMOTO Front Axle Slider: Ducati 1199/1098/848 SF S4Rs
$59.99
Fork sliders help protect the front axle, axle nut, fork bottoms, brake calipers and wheel during a crash and slide.
This kit installs in less than one minute per side with only a 5mm key key. They remove just as quickly for maintenance and can be reinstalled virtually an unlimited number of times.
AEM 6 Hole Sprocket Hub Cover
$149.95
Weighing just 0.55 lb, the AEM Sprocket Hub Cover reduces un-sprung and rotating mass.
Pictured with
CORSE DYNAMICS Titanium Cush Drive Pins
$369.95 /set of 6
Grade 5 Ti6Al4V cush drive pins combined with a propritary urethane cush drive for optimal performance and weight reduction.
The combination weighs .65 pounds lighter than original
Ducati 1199 Mirror block off plates
CORSE DYNAMICS Mirror Blockoff Plates - Ducati 1199 Panigale
$54.95/ pair
in stock
Clean up the front end of your Panigale with a set of Corse Dynamics mirror block off plates.
CNC machined billet aluminum in the United States of America
Available in black anodize only
Original mirror weight - 2.5 lbs
Block off weight - 0.10 lbs
2.4 lb savings
Discussion Starter #6 (Edited)
OBERON "Bar End" Turn Signals Kit: Ducati 1199 Panigale
Bi-directional LED handle bar mounted motorcycle indicators from Oberon Performance that flash front and back to increase visibility. Available in black or silver.
Since the 1199 Panigale uses a threaded handlebar this kit was developed to save from damaging those threads when using the bar end turn signals by. Instead of using an expanding collet this kit uses a larger hollow bolt that threads into the stock handlebars. If you already have bar end turn signals you can order just the fit kit separately.
Pricing:$189.00
pictured with CRG Blindsight Mirror: Black
Discussion Starter #7 (Edited)
CORSE DYNAMICS Ride Height Tool: Ducati 1199 Panigale
With adjustable linkage featured on the 1199 comes the need to keep track of ride height, ride height controls every aspect of handling and is crucial in being maintained. This tool easily slides into the frame on the left hand side for consistent measurements everytime.
*Will not work with DP rearsets as the frame support is changed on these rearsets
Made in the United States of America
Measure ride height with ease and 100% accuracy everytime
ETA ship date 5/23
$69.95
Discussion Starter #8 (Edited)
CORSE DYNAMICS Rear Brake Caliper Bracket - 1199 (Increased Wheel Base)
Increase wheelbase at a fraction of the cost of a new swingarm
Rear bracket adds an additional 5mm of length for additional stability and tire clearance.
CNC machined and FEA tested for optimum strength & weight
Please Call for Availability
916.369.2509
Currently in R&D planned ETA of June 1st
Discussion Starter #9
CarbonVani Carbon Fiber
Some CF on route from Italy ETA 06/20/12
Carbonvani Carbon Fiber Belly Pan Street: 1199 Panigale
$588.00
BELLY PAN - ROAD VERSION
Carbonvani Carbon Fiber Exhaust Guard: 1199 Panigale
$273.00
EXHAUST COLLECTOR GUARD
Carbonvani Carbon Fiber Front Fender: 1199 Panigale
$259.00
FRONT FENDER
Carbonvani Carbon Fiber Full Fairing Street: 1199 Panigale
$3080.00
FULL FAIRING -ROAD VERSION
Carbonvani Carbon Fiber Headlight Fairing Street: 1199 Panigale
$812.00
HEADLIGHT FAIRING- ROAD VERSION
Carbonvani Carbon Fiber Key Guard: 1199 Panigale
$175.00
Discussion Starter #10
Discussion Starter #11 (Edited)
STM Elliptical Reservoir: Brake 40cc
STM Reservoir: Brake 40cc
Was:$94.95
Sale:$90.20
STM elliptical clutch and rear brake reservoir. The STM reservoirs utilize the original mounting bracket so they are a simple install, though you will have to add more fluid and re-bleed your system upon install. CNC machined from billet aluminum and anodized in black, gold or red. 40cc Fluid capacity.
STM Reservoir: Clutch / Rear Brake 20cc /45º
Was:$88.95
Sale:$84.50
These reservoirs have a 45º outlet. 20cc Fluid capacity.
Discussion Starter #12 (Edited)
CORSE DYNAMICS Full Floating Rotor Button
$85.92/set
Made of air craft grade 7068 Hard Anodized Aluminum
Free floating brake buttons will allow you to convert the Panigale's semi floating rotors into full floating rotors. Free floating rotors reduce the drag from the pads which in turn reduces the heat build up in the rotors and the heat transfer to the fluid. These free floating buttons will allow the bike to roll easier and reduce the unsprung rotating weight by over .5 pound. Hard Anodized aluminum buttons with stainless steel clips.
Designed for all Brembo rotor applications OEM & Aftermarket with 5mm thickness. Sold each (12 needed for the 1199)
Discussion Starter #13 (Edited)
NK Components Titanium Rotor Bolts
$89.50 set
These ultra lightweight bolts are constructed of Ti6Al4V Grade 5 Titanium, precision machined with a hex head, torx inner provision, and center gun drilled entirely through the bolt for optimum weight savings.
These bolts measure M8 x 20 / 1.25 pitch, weighing 4 grams per bolt.
Designed as rotor bolts for all Ducati and Aprilia applications. Sold each. The 1199 Panigale requires 10 bolts for the front rotors.
Discussion Starter #14 (Edited)
Titanium spring for the 1199
Titanium spring.
2.4 lbs OEM spring
1.0 lbs titanium spring
Saves 1.4 pounds.
Since the titanium spring isn't wound as tight there is no need to run the plastic shock guard, further showing off the cool spring.
Contact [email protected] for details on the lightweight titanium spring.
-M
Discussion Starter #15 (Edited)
CORSE DYNAMICS Clutch Cover: Ducati 1199 Panigale
Ducati 1199 Panigale: CORSE DYNAMICS Billet Clutch Cover
Retail:$249.95
Constructed of billet aluminum with crash protection and abrasion resistance in mind.
After extensive R&D we have determined the clutch cover is going to be one of the main impact points in the situation of a crash on the right side of the 1199 Panigale. The factory cast clutch cover in abrasion locations is less than 0.080" thick leaving no chance of containing oil in the case of impact.
Corse Dynamics has designed a complete replacement clutch cover (AMA homologation pending) to ensure oil containment and abrasion protection, keeping you on the road and out of the garage.
Clutch cover has all OEM accessory provisions and is designed to use OEM rubber damper or without to reduce weight.
Discussion Starter #16 (Edited)
OZ Racing Cattiva Magnesium Wheels: Ducati 1199 Panigale
OZ Motorbike Cattiva Forged Magnesium Front Wheel: Ducati 1199 Panigale
$1,848.75
OZ Motorbike Cattiva Forged Magnesium Rear Wheel: Ducati(MTS1200, SF, 1098-1198, & 1199)
$1,746.25
Forged magnesium reduces weight compared to forged aluminum wheels and even some carbon fiber wheels, which decreases the moment of inertia resulting quicker acceleration and braking, lowers un-sprung weight and gyroscopic effect to provide quicker turn-in and more positive handling.
FEM (finite element method) designed to minimize weight and increase strength and rigidity.
Specially treated billet magnesium alloy is bi-directionally forged, resulting in a more uniform and stronger metal structure.
Heat treating, shot peening and CNC finishing are done in house resulting in an extremely lightweight and rigid wheel.
OZ wheels are AMA homologated for racing and also used in World Super Bike, MotoGP 125, Moto2, British Super Bike, IDM German Superbike and [/FONT]Bol d'Or 24-hour endurance racing.
Discussion Starter #19
OZ Motorbike Piega Forged Aluminum Wheelset: Ducati 1199 Panigale
OZ Motorbike Piega Forged Aluminum Front Wheel: Ducati 1199 Panigale
$777.47
OZ Motorbike Piega Forged Aluminum Rear Wheel: Ducati MTS1200, SF, 1098-1198, & 1199
$1,222.48
OZ MOTORBIKE is part of the OZ Group which includes OZ Racing, a company from San Martino di Lupari (Padova), Italy which since 1971, leads the car and motorcycle aftermarket wheel industry. For over 35 years, the OZ brand has been recognized as a symbol of excellent quality and Italian design. And today, with this new project, OZ MOTORBIKE makes its world-wide appreciated and known brand even stronger.
•FEM (finite element method) designed to minimize weight and increase strength and rigidity.
•Reduced wheel weight decreases the moment of inertia which results in quicker acceleration and braking, lowers un-sprung weight and gyroscopic effect to provide quicker turn-in and more positive handling.
•Specially treated billet aluminum alloy is bi-directionally forged, resulting in a more uniform and stronger metal structure.
•Heat treating, shot peening and CNC finishing are done in house resulting in an extremely lightweight and rigid wheel.
•Dot and JWL approved for street use.
•OZ wheels are AMA homologated for racing and also used in World Super Bike, MotoGP 125, Moto2, British Super Bike, IDM German Superbike and Bol d'Or 24-hour endurance racing.
•Included parts: bearings, valve stems, axle spacers (as applicable) and sprocket adaptor.
Discussion Starter #20
CRC Ducati 1199 Panigale Complete Race Body kit
$972.00
All CRC bodywork is fabric fiberglass (unless otherwise stated) finished in grey urethane acrylic primer. Uppers and lowers do not interchange with stock parts or other bodywork company's parts unless specifically mentioned. All CRC bodywork comes un-drilled.
Also available seperately:
CRC Ducati 1199 Panigale Front fender
CRC Ducati 1199 Panigale Left Side
CRC Ducati 1199 Panigale Right Side
CRC Ducati 1199 Panigale Supersport Tail
CRC Ducati 1199 Panigale Upper Race w/ Adapter
CRC Ducati 1199 Panigale Belly Pan
1 - 20 of 77 Posts
