1 - 2 of 2 Posts
Discussion Starter · #2 ·
If anybody is interested in how we replaced the steering stem races, here's our solution. In the frame/airbox there are two removable pieces that the steering stem fits into. We pounded the two pieces out and then we were able to put some weld on the bearing races which made them easy to pry out. The reason we chose this method is that you do not need to remove or isolate the electronics on the bike.
1 - 2 of 2 Posts
