The butterfly valve fitted in the right pipe on the 1098/1198 this is operated by the stock ECU for noise emission, is that correct also is it true that with the Termi/ECU kit the new ECU holds it in the open position??
Is it worth the extra work to remove the butterfly all together for better flow??? or will it make no difference??? Colin.
