1 - 12 of 12 Posts
So today, my buddy lunched the transmission in his 848. It is jammed in between gears 3 and 4 after a downshift on 181. It is jammed in there and there is no moving the lever. So we have come to the conclusion that a motor swap would easier. Has anyone tried putting a 1198 engine in an 848. How much of the harness is the same. the ecu needs a reflash. Need all the help we can get. Thanks in advance.
Sounds like the broken spring behind the shift lever and cover. You guys might have a pretty simple cheap fix on your hands.
My buddy had the same symptoms on this 1098.
Gear lever stuck solid between two gears, couldn't be moved up nor down.
It was still in warranty, but he was worried that because it was in Track Trim Warranty would be denied.
We changed all back to normal street trim, just to drop it of that the dealer.
Half a day later, dealer called. It was just an adjustment problem of the gear actuation system behind the left engine cover. From the gear leaver to the actual gear selector drum there is quite a mechanical system behind the engine cover. If this is out of adjustment it can get stuck in a position where pushing on the leaver will not move the drum at all.
Certainly worth checking before purchasing a new motor!
It will just be an adjustment of the gear selector, the selector drum over shifts and jams the foot of the selector fork, thus not allowing you to shift up or down. Easy fix.
I'll take that junk motor off your hands so you can make room for the 1098..............................................................................;)
Thanks a bunch so on this adjustment what am I looking for. Also do I need to.split the cases to do this?
Discussion Starter #10
thanks!!!! I greatly Appreciate it.
2012 Ducati HyperMotard 1100 Evo SP carbon fiber everything, yoshi pipes, intake, ecu, tune
Anybody know any links on how to stuff that 1098 in a hypermotard 1100 chassis?
Smut peddler
1 - 12 of 12 Posts
