· Registered
1098 w. termis full.
the ECU shows on the dash SBK 1098 message - this means the ECU is.. standard? as far as i knew the dash should have shown Race or Corse message if the ECU was for full termi.
i found a 1198 termi ECU. will it work on 1098? i doubt, but maybe some of you will know better. thanx
· Senior Narcissista
Full termi 1098 ecu displays 1098 Racing, yes.
1198 wont work on a 1098, it wont even start as the startbutton is on a different pin, and maps are off. Its the same hardware as 1098 though, so you can reprogram it with 1098 and it will work.
