OK so maybe the title is a bit cryptic and I haven't had a time to see whats up but checking on the forum for similar experience or wisdom here.
The clutch reservoir is suddenly empty. I see small indications of a leak below the master cylinder on the fairing (washed off) but no obvious signs of a leak. The slave cylinder and hose from the master is bone-dry. I am wondering if perhaps the reservoir developed a hairline crack or the hose from the reservoir to the master or the master seals just up and died.
The bike has barely over 8K on the odo and the clutch lever went to the bar on a short ride but at least on the way home.
I'll look at it tomorrow sometime and report back but hopefully someone has had the same thing happen.
Weird...but it "is" Italian after all.
