I'm using Tuneecu on an android pad to improve the maps on my hyper.
My bike was a US import. It had the US OEM map 22ABLH06 loaded.
I'd never riden a hyper before but heard they were great fun . I've had dozens of bikes over the years, and the most impressive low/mid range bike was a Honda XR650R single cylinder supermotard with high flow filter, race pipes and timing slightly advanced. This hyper isn't as responsive low to mid range as the Honda although still pretty good. The last bike I had was a Suzuki TL1000s which was manic and aggressive in the power department and I loved it. So perhaps I am wrongly compairing bikes that are totally in a different department . I just feel the low to mid range should be more aggressive. The bike seems like the characteristics of a 500cc rather than a 1100.
Anyway.... I uploaded a 22AABA9SHB4 map from the Ducati TuneEcu library (2 into 1 termig setup) which I think is the closest one to my setup from the limited map choice. I disabled the 02 sensor.
I then reset the TPS via the software. The TPS reads 3.4 when shut off and 85% when fully open. Before I installed the map it was 2.6 - 85. This seems odd ?
The bike ran Much better. The riding on and under 50kms per hour is so smooth now. The bike acts as before as regards to mid range and up to 135kms per hour ( pulls nice and quick but not overley impressive ). The pipe seems a little louder too.
One thing I did notice is both the OEM and the termig map have big dips ( I'm guessing retarded spots) in the I2 table. Can these be smoothed out with success ?
I could pull up the fuel curve earlier on the F1 and F2 maps but I'm guessing the injection maps might be more of an issue ?.
