1 - 3 of 3 Posts
Don't want to hijack the 796 thread so here's mine.
I've replaced my stock 1100S brembo levers with eBay fake pazzo's. They work great, except for one small flaw.
The brake light switch engages too late. It only works when I'm braking hard. It seems like it needs a bit more distance between the lever and switch, but I cannot figure out how to remove the switch from the master cylinder. I want to move it back a tiny bit so it engages a bit earlier. Anybody know how to do this?
I did it recently when I replaced my stock master with a RCS.
The switch holds into the master with 2 pins, you just need to pull it hard or use a tiny flat tool to pop it.
I am not sure which levers you run, but the Pazzano levers have a horizontal lever adjustment as well as the on the fly adjustment.
Eric
1 - 3 of 3 Posts
