I just jam a 8 mm ball ended hex key in from the other side. Easy
Good suggestions, thank you! Do ya'll use those tools as a lever, like in this photo?I use a 1/4" diameter aluminum punch from the other side myself it's also used for pounding on that rear shock spring adjuster that's so fun to get at.
Basically if you jam it in under the rocker from the opposite side (from intake side if working on exhaust valve and vice versa) then the handle of the tool won't get in the way, and almost any roughly 1/4" or 6-7mm diameter object should work. I use a 1/4" ratchet extension wrapped in some e-tape, or a brass punchGood suggestions, thank you! Do ya'll use those tools as a lever, like in this photo?
I'm not trying to be dense, I just don't have access to the bike at the moment to try out these suggestions haha.
At around 5 or 6 min into this video, it's explained. Video from a well known forum member![]()
Brilliant. Thank you all for the suggestions. That closer helper spring puts up a big fight! In the many hours I spent researching the desmo valve adjustment process and reading guides, not once had I come across that method of keeping the rocker arm depressed. Thank you very much for sharing the video.Whoever owns that engine needs to change there oil a bit sooner it's starting to discolor the insides or it's been really hot a few times turning things gold colored.
Other than that bit of information that's how it's done on a bench, now do it with a trellis frame in the way.
One more bit of information for you guys trying this for the first time plug the oil drain holes with foam ear plugs or your inevitably going to drop a collet half down the hole causing you to hopefully only going to remove the head locating it or going farther pulling the cylinder if you still can't find it the next step is yanking the motor & splitting the cases looking for the little bastard you dropped.
Or change to MBP collets they are easier to handle, don't wear out & don't fit in oil drain holes.
Try working on an ST3. They have 2 springs!That closer helper spring puts up a big fight!
Damn, that's why it was so painful. That and my holder tool doesn't fit.Try working on an ST3. They have 2 springs!
I've read the stock collets wear down a bit and reinstalling them with the incorrect side up can affect the shim clearance. Is this correct? After taking the collets off I was unable to keep things organized well enough to know if I was reinstalling them in their previous orientation.Or change to MBP collets they are easier to handle, don't wear out & don't fit in oil drain holes.
