The insert on the 1098r can be rotated but you will need to drill a hole for the locating screw, you also lose your steering lock, a 996 insert fits, which you will need to use if you go for 30mm offset and dont want to move the radiator.
Ive been playing around with these things for a while and ended up for the road, standard offset, rotated 1098r insert, forks pushed all the way through and the rear jacked up and have been pretty happy with that
