nWhat about stalling issues i get mixed opinions.
1. Ducati knows the problem
2. They give you a ecu to fix the problem or adjust tps
3. The ecu?tps dosent always fix the issue
4. If they know about the issue why dont they just fix itor have the bikes re-adjusted.
5. We spend are hard earned money to buy a bike we know has issues
6. Its still a BAD ASS looking bike .
The stalling issues arn't something you're gonna run into every day or something. It happens every once in a great while, for me maybe once every two or three weeks and I ride my 848 every day.
The reason the bikes stall is due to the design and you can't 100% guaranteed resolve it. Japanese bikes have injectors above and below the throttle plate. The Ducati superbikes have injectors ONLY above the throttle plates. This means, the air/fuel mixture has to be done perfectly and travel around the throttle plate into the cylinders. This is a lot of traveling for a blend of fuel and air with a piece of metal blocking it. So sometimes the fuel doesn't attach itself to the air very well and you get an alteration in fuel mixture. This happens pretty randomly, usually heat is the cause of it.
So the resolution is quite simple; give it more fuel at idle! If you can set the bike at idle to deliver MORE fuel, you can
almost guarantee, it will run under any idling condition. So this is why people suggest replacing the ECU and such... because the aftermarket ECU's allow for that adjustment by the user or you can have someone reprogram your stock ECU.
Finally, the reason why Ducati uses shower injectors is a positive one for high RPM running, not for idle. Maybe in the future, they'll go back to a double injection system, who knows.
