Does anyone know if you can fit 1098 throttle bodies on a 999?
Its only a thought and just wondering if anyone has tried it.
I have to replace mine and saw a set of 1098 ones with the oval intake, very nice. Plus they are, I think 60mm instead of 54mm.
don't believe that will be an easy fit. You would need the manifolds and some way to adapt the air box.... then there is the matter of fuel flow with the injectors....
What's up with your 999 bodies that requires their replacement? Just curious as I don't hear this very often.
Thanks.
Thanks.
The TPS is faulty:(
It fluctuates and wont stay at a constant reading.
I'm going to fit 999 bodys but I was just curious about the 1098 ones.
