Hello guys,
This clutch problem bothers me a few weeks and I still haven't figured out what's going on. I'm in a small city, at where there's only one ducati dealer in town and they are 3 weeks behind the work!! So, I don't quite want to bring my bike to them unless the bike has some complex mechanical issue.
My bike is 07 1098 with 26k miles. The clutch has replaced with STM Evoluzione clutch as shown in the picture.
Here is the problem:
I've replaced the clutch plates in August myself and the bike works well with new clutch plates. Couple weeks later, the clutch issue happened when I stop at low down the ascent and then I give more throttle to start moving, then I feel the clutch limp.
I've re-checked my clutch work and the clutch plates are in right order. And I didn't see obvious issue as I opened up the clutch. I can see the clutch push rod working as I hold in the clutch lever. I've also bled the slave and master cylinder. The clutch lever feels less pressure as normal before bleeding and it has no improvement after I get clutch bled.
I did some tests to figure out what's wrong with my bike:
If the bike shifts to 1st gear, the rear wheel spins as lifted on rear stand.But the bike doesn't move if unloaded from the stand. As it's in 1st gear and the bike don't move, the bike won't stall. The same thing happened in 2nd gear.
Anyone's bike has similar symptom to mine? I'd appreciate any advice or suggestions.
