1 - 2 of 2 Posts
I did a search, to no avail. Does anyone know if any other Ducati rims fit a 1098?
I'm looking for a set for race rubber.
Thanks!
Thanks!
The rear rim is where you have the problem, the 1098,1198 the rear will fit only those bikes. The front rim you will have better luck, the front rim is the same as 848, 999, 749. All of the other 25mm rims from older bikes will work but with a bit more effort to make them fit, mainly the rotors.
1 - 2 of 2 Posts
