1 - 9 of 9 Posts
Is there any good way of removing the oil screen without breaking it? Man, I broke one already as you can't grab it anywhere decent and now I'm almost temped to leave it and not do it on this oil change! Any suggestions?
Remove the filter while still hot, as the plastic is fragile while cold. I use a normal plier for the job.
Yea, they're brittle.. Best coarse of action is to grab it with a pair of needle nose pliers and gently pull while rocking it back and forth.
4 little screws...
I'm having a bear of a time removing the 4 screws that hold the gauze filter plate. They're probably already stripped. I've drained the oil out so can't run it hot. Maybe I need to return the old oil, run it hot and try again?
ideas welcome, for possible stripped screws removal off that little plate!
Greg
2007 1098
got it done..
OK, my solution for removing the tight little bastard 4 screws holding the sump plate. (Actually, I managed to get one off with the 4mm hex socket! I gave it some heat and hammer taps, and it came loose!) The other 3, I had to Dremel-tool a slot across each head, then hammer-tapped CCW on a thick, short flat screwdriver until they budged. Oh yes, I sprayed some PB Penetrant Blaster on all of them and let them soak for an hour.
Now I've got to find a way to budge the gauze filter screen out without breaking it!
Greg
2007 1098
Senior Narcissista
Something that may help, if entering a problem lid, go for the easy screws first and on the problem one use a mallet to tap the lid along whilst setting pressure on the screw.
Normally the plastic thingy shouldnt require much force at all, just a vice and a yank. Get a good grip with a vice in one hand and then slap your other hand on top, its just an oring holding it.
1 - 9 of 9 Posts
