Hi im a new member who has just purchased a new dash for my 1098 but once installed the bike wont start, is there anyway to overcome this problem or is the ECU/imobilzer coded only for the factory dash???
Can't help but I'm curious about the dash, if you don't mind. Is it analog?
The dash (oem) needs to be programmed to the ecu. If it's after market, you may need race ecu to eliminate immobilizer.
Thanks guys...the dash is a factory 1098 dash i purchased off ebay as my dash was damaged in a crash....
So sounds like i cant use the new dash unless i get the ECU programed to it via a dealer then?. was hoping that i could use the master key then a sequence of dash buttons might do the trick???
