Iam in the middle of a Powercommander install on my '07 1098 and Iam trying to put the tank back on,the problem Iam having is the rear bolt doesnt line up worth a crap,if I force the tank forward I can get the bolt in,if I rock the tank forward and back I can clearly tell its bottoming out on the rubber bungs in front and by the looks of it it cant go any further forward anyway,the tank also goes down on the mounting plate with no effort so I fairly confident that there is no interference with the rear injector hook up.
Is this just the way it goes together with loose manufacturing tolerances?
Any help from someone who has had their 1098/1198 tank off/on would be great.
Thanks
Rich
Thanks
Rich
