Hey guys,
Got the bike running again and took it out for a spin and it was doing this before the issues with the sprag but had just run injector cleaner through there before the sprag gave out so was hoping the cleaner would help clear up the injectors.
If I'm riding along doesn't matter what gear, if I go WOT it will sound like it's cutting out fuel and stuttering but the second I let off it goes normal. I can gradually throttle up with no issues. It has a termi exhaust and a stock ecu and a power commander. I was hoping it was an injector issue that would clear up after running the cleaner through there but no dice. Its starting to sound as if the ecu is cutting it. So my question is
Has anyone come across this and would an aftermarket/race ecu fix this assumably?
I also know it's not like clutch slippage or anything like that either.
I know in the automotive world a weak fuel pump can cause problems at full demand but I guess it could be a million reasons at this point so just seeing if anyone came across this before.
I can try to get a video of it or audio clip if need be.
Thanks!!
Thanks!!
