1 - 11 of 11 Posts
HI again, What's the best ECU to use for track?
standard ECU and remap internally
standard ECU and use piggyback power commander
After market ECU
define "best". powercommander because its simple and user friendly and does the job. but if your engine is running fine then the "best" thing you can do to go faster is hold the throttle open longer in conjuction with using less brakes.
Nope I have a 996 with a 1098 running 996 electronics which works 85% ok. I want to clean the bike up and use the 1098 loom, coils, ecu and dash. Idea is that I can better tune the engine, with it's pistals pistons, aKro exhaust, and one off air box.
Previously I had limited adjustments through a PCIII.
Now to figure out how to mount he wheel sensors :)
All DIY. Everything you need comes in the package, just add dyno. You have control over everything that an ecu is capable of doing. If you don’t have dyno access or you want to tune on your own then you will need the Microtec logger and wide band O2 sensors fitted to your header pipes. These are extras that you will need to purchase.
Discussion Starter · #9 ·
Great just ordered one. I think it's exactly what I need. Any real benefits for having the logger, does it really make that much difference from???
Excel Addict
2001 900SSie
Microtec with logging or stock ECU with logging is the way to go.
Even unmodified bikes benefit from logging and remapping.
1 - 11 of 11 Posts
