Hey all!
Today I was attempting to install a carbon solo street tail and carbon anti-draft section from OPP/Full Six which is a pretty reputable brand with known great fitment. I've sent them an email as well but wanted to reach out to all of you as well.
After installed I have about a 1/2" gap between where the anti-draft and tail section should be touching/connected. This is the first time this bike has seen bodywork (built it from the ground up) so I don't have any other bodywork for reference. From the drawings/microfiche I've referenced I believe I'm installing everything correctly and the carbon pieces do line up with the mounting holes etc.
So it's one of two things, either I'm missing something and I've somehow installed it incorrectly or there is a design issue.
For the main tail section, there are only 4 mounting holes near the seat, two of which share the same two holes as the rear of the seat. The anti draft has two mounting holes basically under the seat and then the 4 holes where the exhaust hanger/mount is. The anti-draft piece is pretty much butted up right against the sub frame so I don't see how it could go up any further. So that would mean the main tail section would need to lower somehow so it's butted up against the anti-draft.
Thanks for any input!
