Hey all ...it's been awhile since I've been on this forum. My 06' ST3 had been running completely fine until this morning. I pulled it out of the garage, started it up, everything seemed normal and while it warmed up I was gearing up. Just as I was about to leave, I noticed the check engine light come on. I've had the bike for 6.5 years and it's been pretty much bullet-proof during that time. I shut the bike off and attempted to restart it to see if the check engine light would come on again. This time, it turned over for a second, then stopped cranking even with the starter button depressed. I then tried again and this time it's not even turning over and the dash lights were flickering as I held the starter button down. At that point, I rolled it back into the garage.
The last service I did was this past January when I changed the oil & filter, cleaned the DP air filter, replaced the starter switch, and serviced the fuel system with new hoses, filter, O-rings, clamps.
Since the bike is not even turning over, I don't think it's fuel pump-related. Seems to be something electrical, maybe a bad main fuse?. It's got about 16,125 miles on the clock.
Any ideas what it could be? Hoping I can repair this in my garage rather than have to tow it to a mechanic.
Thanks!
Steve
Thanks!
Steve
