1 - 3 of 3 Posts
1) Why is it that new oil may be running 10Deg. warmer than before the change?
2) What is the total amount of oil fill on my bike? I allways was told to fill until your at the lines...when running or when its cold? I figured cold...
In between the lines but absolutely no higher than the top line...After the bike has been cranked up and then sits for several minutes. You want the filter and everything full when you take your reading. No idea on the first question.
Check oil level when engine is warm. So it may take a few minutes, fill warm up, fill warm up, fill, warmup ect......
1 - 3 of 3 Posts
