1 - 2 of 2 Posts
I had the headlight assembly replaced on my 999 because the low beam was pointing way too high from the factory, and neither I, nor my old mechanic could adjust it. Now my new assembly is pointed way too low, and it wont adjust either. You can spin those adjusters all day. No effect.
Has anyone else had this problem on the 749/999? Is it a common fault? Looks like I'm after another new assembly.
i thought the same about mine, but kept spinning and it slowly moved. i just shined mine on the garage and only by looking at the joints in the door (straight horizontal lines) was i able to see that the knob was actually working. i'm sure you've tried something similar, so maybe your's is broken :confused:
1 - 2 of 2 Posts
