Anyone know if it is possible to switch from a coffin style master cylinder to a master cylinder with external res. Also I have a bent brake lever any recommendations for aftermarket levers. Not changing master cylinder because of lever just curious about performance gains. I like the look better with non-coffin types. Thanks for input great site!
I read through the previous related posts. Correct me if I'm wrong but 748/916/996/998 brake parts should work on my 800ss??
superbike brake parts will only work if you change the calippers and the
master cylinder at the same time.
it is a matter of master to calipper surface ratio, me and others have
written posts about it, the keyword "ratio" will help with your search for
sure, my post has been written in the sport classic section.
cheers.
800SS
Have you considered the Brembo "gold" line that came std. on the 750SSs. 03 800SS, 900 and 1000SSs, too? I swapped the bake and clutch controls from my 750SS to my 800SS without problems.
