Hi all...
Having some issues with my 04 duck. Had it in to corsa superbike in WI. for recent 12K mile service. They went through the bike, happy overall. However it was mid winter when they had it, and without test riding they would not of noticed the issue with the bike. Seems to be that the head bearing needs tightening, not sure? When going over railroad tracks or several small bumps there is a shutter in the front end. Any ideas or suggestions?
Thanks.
Super Moderator
Sounds like you should get a service manual before you do anything. There are torque specs to be aware of. You should probably grease the bearings and races while you are close to taking it apart. Also, check everything else up front : Axle, pinch bolts, caliper bolts. Grab the front brake and try to roll the bike forward and see if you can simulate the clunk.
