'99 & later ST2 and '04 & '05 ST3 exhaust question...
Hey all you lucky devils with a '99 or later ST2 or an '04 or '05 ST3!
Jeez that's wordy... but I'm trying to be specific, oh, and yes I searched first with no results.
If you remove your pipe(s) completely from the crossover/pivot joint, and look at the inlet, is it double walled with a small gap between the walls? And is the crossover pipe outlet also double walled with the same small air gap?
Thanks.
Thanks.
