1 - 9 of 9 Posts
Hi guys ~~
My bike had clutch slip since yesterday~ and it is clearly getting worse~!!
starting from 1st to 4th gear ~ on hard accleration , clutch slips from
5000rpm to ~ 8000 rpm ~!! And when I slow down , clutch engages
again!
Here comes my questions ~!! Is this problem happening because of the
clutch plates like I said??? Also can it be fixed by "DIY" or would you
rather recommand have the Ducati dealer to service it ~!
Plus my bike has "BUCCI Slilpper Clutch" can this clutch system can use
any Clutch disks?? Or do I have to buy the one specifically for Bucci~
It looked like it had 12 tooth ~!!!
I attach a photo of my clutch ~ Please have a look n tell me if I actually
have a "Bucci slipper clutch" ~ there is no signs of logo on this thing ~!!!!
Thank you for your time ~!!!!
Yes, bad clutch plates would be a good reason for the clutch to slip. Happened to me when my I first bought my bike with 4200 miles.
Changing clutch plates is easy job ~ 30 mins. Not sure about your Bucci clutch pack compatibility. If you're not sure about the type of plates, just pull 'em out (remember the order you pulled em out), and post how many friction plates, metal plates you got in the pack. Someone here can tell you if its the same as stock plates. AFAIK surflex slipper uses different plates, and different pattern than stock, no clue about Bucci (honestly, never heard of that brand)
Hey `~~ Thanks for the input ~! I asked the guys at the motowheels n sent the
photo of my clutch. It turns out , I have 2nd generation Motowheels slipper clutch!
Orderd new clutch pack. Do they ware out fast??? I mean my bike only has 3000 miles~
Its not like I down shifted at 60 mph to 1st gear every day ~!? Come on !!
Also what kind of maintanace and operation do I have to do ? In order to make a good
use out of them !!??
The clutch should last many, many more miles than this.
A clutch failure at 3,000 miles means either that it was setup improperly and/or tremendously abused.
Most likely setup improperly.
Discussion Starter #9
Your plates don't look very worn out, to me anyhoo.
Well the clutch pressure plate looks ok ~ but I am pretty sure there is
something wrong with the clutch disks ~!! I just dont have time till Thursday
I'll have to open it up to be sure ~!!!
1 - 9 of 9 Posts
