1 - 6 of 6 Posts
Hi ~~ My bike is 03 999S with 3000 miles on it. `
I just got back from a grocerry ride ~~ and my bike felt little bit strange ~
As I engage the 1st gear and rev it up ~ When I pass the 5000 rpm range ~
It felt like there was no power delivery ~ !!! As if clutch was engaged!!!
and this symtom happens untill 8000rpm and than it starts to accelerates
as normal ~!!! At first i thought " Did I squeezed the clutch lever???? "
But it wasnt.
Why is this happening ???? Do I have some clutch problem ??? or the trans
problem ????Maybe the Chain?????
Any thoughts will be deeply apreciated ~!!!! Thanks ~!!!!!
could be a sticky clutch slave. Definately doesn't sound like a transmission problem.
Could you explain little more about the part " sticky clutch ~" !!
Is this happening because of some air in side the clutch fluid? or because
of wared up clutch????
Sounds like a worn out clutch pack. You need to remove the pack and visually inspect it I'd say.
Once you remove the clutch pack , would I be able to tell the ware ~
easily??? Also my bike has Bucci slipper clutch ~ Dose this make any
differance, interms of removing the clutch pack!!
1 - 6 of 6 Posts
