Hi, after 2 years of stock suspension i pull the trigger:
Andreani fork cartridge and du321 shock.
I weight only 60kg in riding gear.
The fork cart come with 8.3Nm springs
The stock lenght was wrong and so i have to short it?
Even lowering the oil level from 120 to 135mm there is about 30/35mm of true unused stroke (rider sag is 40mm)
The low speed damping is little pogoing (underdamped) but i cant damp it more because it is already harsh on high speed.
The shocks take 2 month and half to come with 100Nm spring.
It is a good improovement on high speed damping (square edge bumps) but is harsh on all other condition and i can use only half of the stroke ?? (even with spring preload reduced from 17 to 11mm to have 35mm of rider sag and rebound from 14 to 19 click)
I need some help please....
