1 - 7 of 7 Posts
I've been having an intermittent no spark issue on my '02 900SS nearly the whole time I've owned this bike. One day it may start and run fine all day long, the next day, nothing. I'm afraid it's going to leave me stranded. The fuel pump is priming and the engine will turn over fine, but it's getting ZERO spark at either plug (new plugs and timing belts, BTW). I've checked the fuses and everything is fine. The battery has been charging on 2 amps for a couple days now, but still no spark. I got it to run a few days ago by cranking my battery charger all the way up to "engine start". I'm at a loss here. Is there an ignition relay that could have went bad? I'm ready to go beat this thing with a hammer :mad:
Excel Addict
2001 900SSie
Timing sensor
Start from the timing sensor - see attachment and work your way through to the spark plugs.
Check the 750SS thread that is high on the list of threads for the wiring diagram and legend I just posted for a 900SSie 2001
Richard
does the pump run while it's cranking? if not, the ecu doesn't know the engine is turning, probably rotation sensor issue or loom thereof. one place to look.
check the relays as well. those little siemens ones can be crap. just because it's clicking doesn't mean it's any good, altho it's usually the fuel pump ones that don't work.
I don't know anything about injected models, but I had this problem on my '97 900ss and the issue was one of the OEM coil wires had become disconnected at the coil. I pushed it back up there just a little, the bike ran fine. They actually screw into the electrode inside the coil. I replaced the coil wires with a set of TPO Dragons, they fit very tight and are going nowhere. All is well.
1 - 7 of 7 Posts
