First off my question, will a new, supposed virgin, Ducati Performance ECU #96506100B made for the 01-S4 work with a bike that has had the IMO removed with unchipped keys?
The back story of how I got to this point, about a month ago I picked up this 01 S4 from our local Copart. Bike was unwrecked, and came without keys, picked her up for only $450 bucks plus fees, paper work said it was donated, bike has 18k miles. First off bike was in fantastic shape, other than the obvious that it had been sitting out in the weather for a while, all fluids looked to be recently changed, no grime, dirt or leaks to indicate this bike was anything but loved by the previous owner. Only issue, without keys I had no way of testing anything, so I swapped out all the locks and ignition with a spare set I had (Unchipped keys) at least now I could test everything, of course bike would not start due to the immobilizer so after a search I found a guy in the UK who could disable the IMO feature in the ECU, guy Fixed it and returned the ECU this week. Before attempting a start I decided to check for spark. Well, here is where it gets interesting, I get a single spark soon as I crank bike then nothing, I get same result on both cylinders, turn off key try again, same result. Needless to say bike did not start when I hooked everything up. So after some forums searches I found another guy in the UK who had the same issue, after months of failed attempts and about 10 pages of advice he swapped ECU and bike fired up. So fast fwd to today. I found me a new DP ECU #96506100B which is made only for the 01-S4 with slip-ones and open air box, so I bought it last night.
Some cool history with this bike i was able to uncover, Bike was originally bought in Italy, I assume by an Army guy/gal, as it has a service decal from Team Agostini in Vicenza Italy under the seat, with the name D. Croket written with a white paint pen, I assume so dealer didn’t mix up seats while it was being serviced. Bike has European switch gear so lights can be turned on/off or use the mandatory parking light for nighttime parking in Europe. There is also a army base decal on the fork leg for a base in Alabama. So my guess D.Croket bought this in Italy, when they got orders back to the USA they brought the bike with them, somewhere along the line, bike possibly died due to a bad ECU it sat around as owner couldn’t get it fixed, then ended up in this situation either abandoned, stuck in a storage unit, left with a relative, who knows. My only hope is I get get her running again and finally hear this ole girl purr after all these years
