So what is the deal with the 28,29,30mm slave clutch? Why should I care and what’s the one most Hypermotard’s 1100 2008 carry, OEM I mean? Thanks
Retired Pipe Polisher C2H6O+
Your owners manual will tell you what size your OEM is.
Ah, ok, but, what is the difference between those sizes? Besides 1mm of course ?
The larger the diameter of the clutch slave cylinder, the lower the lever pull force needed disengage the clutch. However, with a larger the slave cylinder, the piston moves less, so the clutch plates separate less. This causes clutch drag and difficulty finding neutral at a stop. I recommend 28 mm to avoid these issues.
Thank you! Will follow advice! :)
