Oil Change question on the 2019 Hyper - Page 6 - Ducati.ms - The Ultimate Ducati Forum
post #51 of 64 (permalink) Old Aug 24th, 2019, 8:42 pm
Originally Posted by jbequer View Post
10nm sounds correct, thanks.
Still confused on the size of the hex socket. I keep reading about using 14,17 even 18 ??? What is the confusion with this?
I think it's 14 - did it a while ago and have a long 14 allen and a long 12 but not the other sizes. The 12 is for the rear sprocket -so 14 is the ticket.
appliance57 is offline
post #52 of 64 (permalink) Old Aug 24th, 2019, 8:43 pm
Gus duc, your the man.. Waiting to order whichever size is needed..
jbequer is online now
post #53 of 64 (permalink) Old Aug 24th, 2019, 9:03 pm Thread Starter
I tried a 14, it was too small. I think it has to be closer to 18mm. Waiting on confirmation.
Pard is offline
post #54 of 64 (permalink) Old Aug 24th, 2019, 9:34 pm
It seems like from 14 mm and larger seem to fit, but luckily some of you have not stripped the filter yet? I would really want to know which it is before jacking it up.
I think I will call Ducati service to see what they say.
post #55 of 64 (permalink) Old Aug 25th, 2019, 1:08 am
Originally Posted by Pard View Post
The mesh screen seems to be bigger than 14mm. The side plug is 14mm but the plastic screen is bigger I think. I tried 14 on it and it was too small.
sorry, you're right. the later 4v models have the all plastic screen. pretty sure it's 17. not sure that i'd try to put 10nm on it. doesn't the blanking plug have a form on it to hold the screen in? i forget now, haven't had many of them apart.
the older screen with the steel end is 43nm.
know all wanker
belter is offline
post #56 of 64 (permalink) Old Aug 25th, 2019, 1:16 pm
gus duc's Avatar
Sorry for the slow reply...4 kids kicking my ass🤣
It’s 18mm & it’s not much more than finger right.
Pard likes this.
gus duc is offline
post #57 of 64 (permalink) Old Aug 25th, 2019, 1:26 pm
Thank you very much..
post #58 of 64 (permalink) Old Aug 25th, 2019, 1:37 pm
The other question is , how long does it have to be ? Would this work ? If the body of the socket fits into the hole where the filter is , it should work.
https://www.amazon.com/Titan-Tools-1.../dp/B004W7GPHO
post #59 of 64 (permalink) Old Aug 25th, 2019, 2:05 pm
gus duc's Avatar
It should as long as that socket is not too big. Length is not an issue as you can just pop it on a 1/2 extension & turn by hand.
gus duc is offline
post #60 of 64 (permalink) Old Aug 25th, 2019, 2:49 pm Thread Starter
Itís 18mm & itís not much more than finger right.
Thank you!
Pard is offline
