2015 SP rear brake pedal limp after siting for 4 months - Ducati.ms - The Ultimate Ducati Forum
post #1 of 6 (permalink) Old May 8th, 2019, 7:58 pm Thread Starter
Farmer-Ted's Avatar
I got my 2015 Hypermotard SP out of 4 months of winter storage and the rear brake pedal has gone flaccid and has excessive travel. Basically I have to push on it way down with my heel before any braking (weak) occurs. There is no sign of any fluid loss. No leaks and the reservoir is full of fluid. It does not build up pressure if the pedal is pumped repeatedly.
Any idea what could cause this and the fix? I was going to bleed it but is there a special procedure for bleeding the rear with ABS?
2015 Hypermotard SP
2013 Hyperstrada (sold), 2009 Hypermotard (sold), 2005 999 (sold)
Farmer-Ted is offline
post #2 of 6 (permalink) Old May 8th, 2019, 8:18 pm
1198SP's Avatar
The soggy rear brake comes standard on all Ducati's. I'd be happy to walk you through the procedure but in all honesty, it is one of the most commonly asked questions on every Ducati forum. Do a quick search on bleeding the rear brake and I'm sure you'll find more info on the topic thank you could ever desire
1198SP is online now
post #3 of 6 (permalink) Old May 9th, 2019, 12:20 am Thread Starter
Farmer-Ted's Avatar
It wasn't just soggy, it required virtually the full master cylinder stroke before it would start to engage the brake. You could not push the pedal far enough with your foot still on the peg.
But oddly enough, I went back out tonight and it is working fine again. Brake engages with about 1-1.5" of travel. I'll leave it alone for now.
2015 Hypermotard SP
post #4 of 6 (permalink) Old May 9th, 2019, 3:53 am
If it wasn't air in the system, what it may have been was the rubber piston seals around the caliper pistons which by virtue of design pull the calipers away from the disk after you release pressure on the pistons, simply drew the pads pretty far away from the disks.
This is not unheard of if the bike sits for a while. It can even happen overnight to some degree, but usually goes unnoticed.
https://www.aa1car.com/library/brake_calipers.htm
https://www.youtube.com/watch?time_c...&v=PE7yFJ8ldVc
Pard is online now
post #5 of 6 (permalink) Old May 9th, 2019, 7:43 am
Images: 4
Iíd still bleed it. You donít want that happening when youíre riding.
duc96cr is offline
post #6 of 6 (permalink) Old May 23rd, 2019, 11:38 pm Thread Starter
Farmer-Ted's Avatar
Went ahead and bled the rear brakes and haven't had any issues since. Could anything in the ABS module have caused this?
2015 Hypermotard SP
A new theory of that crappy rear brake... drdave39 Multistrada 77 Apr 9th, 2019 9:24 am
New way of fixing your useless rear brake when all else has failed Damascus Multistrada 44 Feb 17th, 2019 6:46 pm
Rear Brake Problem Daniel Blade Amos Monster 9 Sep 5th, 2017 8:49 am
Ducati 998 Rear Brake Issues Heisenberg Tech Forum 2 Aug 9th, 2016 8:15 am
WTB OEM Black Rear Brake Pedal 999 RC51-05 Parts and Accessories 2 Feb 11th, 2016 9:29 am
