821 4 spring pressure plate fractures - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By araitim
post #1 of 3 (permalink) Old May 5th, 2019, 9:18 am Thread Starter
araitim's Avatar
SON OF A BISCUIT!!! While doing the factory pro detent mod to eliminate false 5-6 neutral as well as make it easier to find neutral I discovered the clutch pressure plate is cracked up. I believe it probably happened because I started using engine braking more aggressively. I ordered a new billet piece and did the 2 day shilling to get back on the road. The bike is used as daily transportation so I hate to have it down. The broken piece was very difficult to get out. The spring pockets are spread out locking it into the Adler slipper piece. I dont have a clear cover yet but the pressure plate ordered is black with a red spring retainer . I tried to braze the piece for a temp fix but then noticed the other cracks.
ID:	942399   Click image for larger version
ID:	942401   Click image for larger version
ID:	942403   Click image for larger version
ID:	942405   Click image for larger version
araitim is online now
post #2 of 3 (permalink) Old May 5th, 2019, 9:28 am
Frustrating indeed, yet lucky you found it before it fractured to bits and caused more damage.
Educate me, what is the shift mod all about? Links to a write up somewhere?
The false neutrals I still get are few and always my fault by not using enough pressure to shift.
Does this mod eliminate the need for so much force to make a clean shift?
Pard is offline
post #3 of 3 (permalink) Old May 5th, 2019, 9:40 am Thread Starter
araitim's Avatar
It actually takes more force to shift but it's a positive feel when it happens. Like a pop them locked in gear till you change. I'm reading that the shifting issue is a common Ducati trait. The kit uses a ceramic ball bearing roller and a thicker stronger spring. The bearing is ment to make a smoother roll. The company that makes this kit is Factory Pro. It is sold a few places. I believe there is another company making one too but dont quote me on that. Factory pro's website is very hard to navigate but here is a links
http://www.factorypro.com/Prod_Pages...motard,16.html
Pard likes this.
Narrow convex steel plate in clutch stack? Z06C5R Superbikes 12 Jun 24th, 2017 6:55 am
EVR Clutch Pressure Plates for DUCATI moto Vendor Deals 0 Sep 15th, 2016 7:43 pm
EVR Clutch Pressure Plates for DUCATI moto Vendor Deals 0 Jul 24th, 2016 8:02 pm
EVR Clutch Pressure Plates for DUCATI moto Vendor Deals 0 Mar 25th, 2016 4:56 pm
