Left hand rear brake control - Page 9 - Ducati.ms - The Ultimate Ducati Forum
post #81 of 94 (permalink) Old Jun 26th, 2019, 12:12 pm Thread Starter
Originally Posted by Pard View Post
Found this lever. Supposed to allow for a closer to the bar setting than stock. Hope it works!
Magura HC1/195 Close Reach Lever - Black Long [2701156] - $49.99 : The Sic Shop, Stunt Parts Store
Installed this lever from the Sic Shop. It is perfect. Allows for much greater range of distance from the bar for a perfect customized fit.
Without a doubt, this mod, the left hand rear brake is the greatest enhancement to motorcycle control I have ever come across. Fingertip control of rear brake should absolutely be something everyone should try.
So, which one of you is going to try this mod next?
Pard is offline
post #82 of 94 (permalink) Old Jun 26th, 2019, 12:18 pm
Without a doubt, this mod, the left hand rear brake is the greatest enhancement to motorcycle control I have even come across. Fingertip control of rear brake should absolutely be something everyone should try.
Me. Well, maybe not ~next~ however it's most certainly on the long-range list of things I want to employ. I am a believer of trail braking and using the rear brake to assist in cornering. When you're playing ~monkey~ in corners the right boot isn't always in a position to use the rear brake in a finely controlled manner. Right hand braking is something that has appealed to me for at least a solid three decades.
As has using a thumb throttle, akin to what ATV/Quads/ATCs use. But that is the subject of an entirely different thread.
Pard likes this.
1996 900CR.
Rex Coil 7 is online now
post #83 of 94 (permalink) Old Jul 8th, 2019, 12:31 pm Thread Starter
Pard is offline
post #84 of 94 (permalink) Old Jul 8th, 2019, 6:54 pm
araitim's Avatar
Looks fantastic! Great job!
Pard likes this.
araitim is offline
post #85 of 94 (permalink) Old Jul 9th, 2019, 12:27 am
... I'm diggin' on that thumb lever operated type by IMA. I like that it offers bar-mounted .. and/or .. fork mounted options for the actuator and the fact that the kit is mostly complete, sans hydraulic line (that must be fitted to each application, so they're not included in the kit).
LINK = IMA Thumb Brake - Superbike Source Pty Ltd
Considering it includes both foot operated master cylinder and thumb operated master cylinder, and they are designed to work with one another, there's a little more confidence in it's trustworthy operation. The multiple ways the thumb lever can be adjusted is another well thought through feature.
$499.00 is actually reasonable, all things considered.
I think if the thumb brake is mated with a slipper clutch those two working as an ensemble will actually entirely change the way one rides. Everything from body positioning, right and left foot position on their pegs while cornering, and overtaking in corners will be rethought and adapted to the new ways of controlling the bike the slipper clutch used with the thumb rear brake as a combined ensemble will offer.
Every bit as revolutionary as foot operated gear shifting with left hand clutch was when it was adopted.
I really do believe this.
Imagine how useful it would be on motocross bikes! You could drive into right hand berms every bit as hard as left hand berms since rear braking is no longer dependent on the right foot being on the footpeg to operate the rear brake in right hand turns. Same with being airborne ... foot position on the pegs will no longer be dictated by the need to lock up the rear wheel in mid air to control the bike's attitude in flight. That can be done with the right thumb instead, so foot placement on the footpegs can be focused on body weight distribution rather than being able to operate the rear brake in mid air.
All of these wins! So many wins! I'd bet money left hand rear brake systems will become standard equipment sooner than later.
Yup.
Pard likes this.
1996 900CR.
post #86 of 94 (permalink) Old Jul 9th, 2019, 9:24 am Thread Starter
Question for anyone in the know...
I think I want to have a brake light switch on the left hand rear brake master. The Magura comes with a switch currently not wired up.
Can I splice that switch in line, parallel, with the right hand front brake switch? I assume they will both work fine if either one is depressed, but what happens when both are depressed?
My assumption is that if either plunger switch completes the circuit, lighting up the brake lights, it won't matter if the other switch is on or off in a parallel circuit, the circuit is still complete if wither switch is triggered on, and the tail lights will illuminate.
I will try it out and test that theory, just fishing for info if you have experience.
Pard is offline
post #87 of 94 (permalink) Old Jul 9th, 2019, 12:07 pm
araitim's Avatar
If you use a banjo pressure switch instead of a banjo bolt on the line running to the caliper it will illuminate the rear light with the front master or the rear once it senses pressure. This method would help eliminate additional wiring up to the handlebars.
https://www.jpcycles.com/product/561...4aAtjfEALw_wcB
araitim is offline
post #88 of 94 (permalink) Old Jul 9th, 2019, 12:12 pm Thread Starter
That is a good idea, but at this point, I am not interested in having to bleed the system again. The lever switch would be the least amount of fuss, assuming it works.
Pard is offline
post #89 of 94 (permalink) Old Jul 14th, 2019, 6:29 pm Thread Starter
Wired up the Magura brake light switch wires on the left with the Brembo light switch wires on the right in parallel, and they work as they should.
Took only a few minutes to solder it all up.
Pard is offline
post #90 of 94 (permalink) Old Aug 4th, 2019, 8:26 am Thread Starter
Dovi uses a left hand thumb brake for cornering. Note the two reservoirs on his left bar. One for clutch, one for rear brake.
https://www.brembo.com/en/company/ne...-brembo-brakes
https://www.motorsportmagazine.com/o...ool-press-turn
Name:	two reservoirs.PNG
Pard is offline
New way of fixing your useless rear brake when all else has failed Damascus Multistrada 54 Jul 14th, 2019 10:30 am
Smart Brake Module from STS install on 2013 Diavel Occams_Razor Diavel 2 Jan 17th, 2018 6:46 pm
Rear Brake Problem Daniel Blade Amos Monster 9 Sep 5th, 2017 8:49 am
Íhlins Suspension Control Unit 35000-03 - $325 with FREE shipping johnchypermotard Parts and Accessories 1 Oct 27th, 2016 11:21 am
Ducati 998 Rear Brake Issues Heisenberg Tech Forum 2 Aug 9th, 2016 8:15 am
