Left hand rear brake control - Page 6 - Ducati.ms - The Ultimate Ducati Forum
post #51 of 92 (permalink) Old May 11th, 2019, 11:25 pm Thread Starter
Well, a bit of a setback.
Installed everything, used the motive pressure bleeder from the lever reservoir and was able to get solid pressure in the system.
Reinstalled the caliper and tested for leaks.
My welding job was not good enough. Small leak from the fitting joint on the brembo rear master.
Next step is to dissemble that master, clean it up well, sand down the joint and re braze it.
Can I just apply more material from the brazing rod over the existing joint? Do I have to pull out the fitting and start from scratch?
Pard is offline
post #52 of 92 (permalink) Old May 12th, 2019, 6:51 am Thread Starter
Here is a picture of the reweld.
I sanded it down and noticed there were some cracks in material. I guess that was the source of the leak.
Heated it up until existing material became molten, then added more brazing material until I had a really nice looking fillet.
Here it is.
Will reinstall and test again.
Pard is offline
post #53 of 92 (permalink) Old May 12th, 2019, 7:27 am
araitim's Avatar
You can always reheat and reflow the brazing material. Usually when it doesnt adhere to the metal is was not clean enough but what you did was perfect. Found the source, sanded and re flow'd the material.
araitim is offline
post #54 of 92 (permalink) Old May 12th, 2019, 8:27 am Thread Starter
Tested it and it still leaks. Almost as if it is porous because I cannot see any defect.
This time I will heat, remove the fitting and as much old material as practical, then reflow.
Patience ....
Pard is offline
post #55 of 92 (permalink) Old May 12th, 2019, 1:44 pm Thread Starter
No Joy.
I cannot seem to weld the fitting adequately. Leaks through the weld.
The fitting and master are pretty much just an educational tool at this point.
I will buy another master and fitting and find a pro to do the welding.
Back to the mechanical LHRB control for now.
Pard is offline
post #56 of 92 (permalink) Old May 23rd, 2019, 7:09 am Thread Starter
An amazing forum member (anonymous until he wishes to be revealed , pics of his craftsmanship below) has welded a new fitting on to my master, so the project is still alive. Leak tests are pending.
In the meantime, I have gone back to stock master and mechanical left hand rear brake.
I am trying to figure out if I have air, water, or just insufficiently high temp boiling point DOT 4 in the system.
At the beginning of the ride, my left hand rear brake is sort of mushy feeling. After an hour of hard and heavy use, the lever becomes very firm.
As the fluid heats up is it causing water to boil, brand new Castrol DOT 4 to boil, or is that air heating up and expanding?
To rule out air and water, I could bleed it again with fresh fluid of the same type.
To rule out the inadequacy of the fluid, I could then bleed with better quality brew.
I may do both.
ID:	943815   Click image for larger version
Pard is offline
post #57 of 92 (permalink) Old May 23rd, 2019, 8:21 am Thread Starter
Buddy of mine is fitting this thumb brake on his Panigale. Very eager to hear how this well engineered system works.
IMA SPECIAL PARTS Volpiano Italy TBS - THUMB BRAKE SYSTEM
https://www.ebay.com/itm/IMA-motorcy...gAAOSwT9lZemSO
https://www.youtube.com/watch?time_c...&v=CJy7Gz58T9o
ID:	943825   Click image for larger version
Name:	bar mounted.PNG
ID:	943827   Click image for larger version
Name:	bar mounted 2.PNG
ID:	943829   Click image for larger version
Pard is offline
post #58 of 92 (permalink) Old May 23rd, 2019, 9:06 am
araitim's Avatar
I will be shipping it back to you today. I thought I had a way to pressure test it but the beringer master cylinder I have laying around apparently needs to be re built. I am bbn very confident with the welds and fitment of the piece I made.
Pard likes this.
araitim is offline
post #59 of 92 (permalink) Old May 23rd, 2019, 9:18 am Thread Starter
AWESOME!
Pard is offline
post #60 of 92 (permalink) Old May 27th, 2019, 9:43 am Thread Starter
The Red Baron has arrived - Page 4
Check out this system. Elegant but expensive.
Pard is offline
New way of fixing your useless rear brake when all else has failed Damascus Multistrada 54 Jul 14th, 2019 10:30 am
Smart Brake Module from STS install on 2013 Diavel Occams_Razor Diavel 2 Jan 17th, 2018 6:46 pm
Rear Brake Problem Daniel Blade Amos Monster 9 Sep 5th, 2017 8:49 am
Íhlins Suspension Control Unit 35000-03 - $325 with FREE shipping johnchypermotard Parts and Accessories 1 Oct 27th, 2016 11:21 am
Ducati 998 Rear Brake Issues Heisenberg Tech Forum 2 Aug 9th, 2016 8:15 am
