2019 Ducati Hypermotard 950 Rearsets - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old Mar 15th, 2019, 10:41 am Thread Starter
2019 Ducati Hypermotard 950 Rearsets and other Mods
Post a link if you find any. The shift lever on the 2019 950 is different than the 939. New designs will be required.
You can view the various bling offerings available from Ducati for the 2019 Hyper on the configurator interface:
https://configurator.ducati.com/bike...rmotard-950-sp
One of the more amusing items is a lower seat for $300 that drops your seat height a full 2 centimeters
Name:	950SP gear shift lever.jpg
ID:	938413   Click image for larger version
Name:	939 gear shift lever.PNG
Pard is offline
post #2 of 11 (permalink) Old Mar 15th, 2019, 11:34 am
Iíve been looking as well but nothing yet. Iíve talked to CNC Racing and they said they are working on it but no dates yet.
Mostly built custom 1098S, been piecing it together, bolt by bolt over the last 8 years
firstascent is offline
post #3 of 11 (permalink) Old Mar 15th, 2019, 1:18 pm Thread Starter
Sent you a PM.
firstascent likes this.
Pard is offline
post #4 of 11 (permalink) Old Mar 15th, 2019, 2:10 pm Thread Starter
The Zeta handguards are installed on both sides. Now I am thinking I need the carbon fiber shields.
https://www.langston-motorsports.com...or-hand-guards
That would require a set of aftermarket LED indicators.
Not at all in love with the stock mirrors. Considering a set of mirrors with integrated signals such as the:
https://www.motovationusa.com/rizoma...ror-bs306.html
Those would look odd on a hyper with off road handguards.
These might work. https://www.kiwavmotors.com/en/parts...mirrors-detail
I had a set of LED Kiwav mirrors on a Panigale 959. Quality stuff. The really cheap ebay stuff is not at all similar to OEM quality.
ID:	938433   Click image for larger version
ID:	938435   Click image for larger version
Name:	Zeta Carbon.PNG
ID:	938437   Click image for larger version
ID:	938439   Click image for larger version
Name:	Zeta carbon on a hyper.PNG
Pard is offline
post #5 of 11 (permalink) Old Mar 15th, 2019, 9:44 pm
gus duc's Avatar
I went with the Ducati Performance Billet pegs. Much gripper than the OEM pegs & super east to install & they still fold. Got them on sale at the dealer for $90.
firstascent and Pard like this.
gus duc is offline
post #6 of 11 (permalink) Old Mar 16th, 2019, 7:38 pm Thread Starter
Those are indeed nice.
On sale here:
https://motowheels.com/i-23900774-du...sert-sled.html
Pard is offline
post #7 of 11 (permalink) Old Mar 17th, 2019, 9:02 am Thread Starter
I found it hard to reach the rear brake toe piece to apply adequate braking force.
The stock lever has some limited height adjustment. I maximized brake pedal height using the set screw, and I turned out the brake master pushrod a full 7 turns to max the engagement of the rear brake to occur as soon as possible with pedal depression. (see pics )
I went the woodcraft eccentric folding toe peg route to modify the brake lever.
https://www.revzilla.com/motorcycle/...ding-toe-piece
This mod was pretty easy to do. It allowed me to find the perfect position for the toe piece, and will fold rather than bend or break in case the bike goes down.
The woodcraft toe piece is mounted with a single bolt through the brake lever. It also has a positioning pin, so in addition to cutting off the stock toe piece and drilling out a primary mounting hole, I had to drill another small hole for the positioning pin.
Looks OK and solved my ergonomic issues. The toe piece is now both closer to and higher up in relation to the foot peg.
Foot pegs need to be changed to more road bike typical pegs. These pegs interfere with my movement around the bike and towards the foot controls.
ID:	938551   Click image for larger version
ID:	938553   Click image for larger version
ID:	938555   Click image for larger version
ID:	938557   Click image for larger version
ID:	938561   Click image for larger version
Pard is offline
post #8 of 11 (permalink) Old Mar 17th, 2019, 11:44 am Thread Starter
I removed the passenger pegs and peg mounting frames and replaced the front pegs with the passenger pegs.
Tricky on the right side because the clutch case prevents the pin from coming out.
Update: This mod works. Just got back from a ride and these pegs make moving around the saddle much more fluid. I can easily move my feet on the pegs and lean off sportbike style with the familiar point of the peg on the ball of the foot feeling.
ID:	938589   Click image for larger version
ID:	938591   Click image for larger version
ID:	938593   Click image for larger version
ID:	938599   Click image for larger version
Pard is offline
post #9 of 11 (permalink) Old Mar 17th, 2019, 6:17 pm
gus duc's Avatar
Great idea to swap the pegs. On my 939 passenger pegs are the same as rider’s but both are better with the rubber removed but not as good as my grippy DP pegs with the knob on the end. I’m a bit jealous at how good it looks with rear passenger mounts removed...not an option for me as they are 1 piece. They do however make an excellent frame slider/Termi exhaust protector.
Pard likes this.
gus duc is offline
post #10 of 11 (permalink) Old Mar 17th, 2019, 8:56 pm
way to be creative!!
Pard likes this.
Hypermotard 821 stock rearsets and Ducabike mount Ratkiller Parts and Accessories 2 Oct 3rd, 2017 4:12 pm
FS: Hypermotard Handguards and Rearsets (rider+passenger) saumo Parts and Accessories 0 Jul 28th, 2017 8:29 pm
Ducati hypermotard 796 rearsets antonio123 Welcome and Introduction 2 Jan 6th, 2017 9:31 am
'08-'12 Hypermotard OEM rearsets COP TZR Parts and Accessories 4 Oct 9th, 2016 11:30 pm
