Has Anyone Else Purchased a 2019 Hyper? - Page 17 - Ducati.ms - The Ultimate Ducati Forum
post #161 of 180 (permalink) Old May 7th, 2019, 4:02 am
Originally Posted by TexasJeff View Post
I'm enjoying my bike as well! Took a trip on a couple of local roads that are twisty and rural this late afternoon.
Does anyone know if there are some larger, mirrors that install easily and "stick out further" on each side? I'm using this bike to deal with Austin traffic and I'm physically too large for the provided mirrors to see around me. I'm not worried if they are dorky looking. My concern is that when I have to make a quick stop I check my mirrors to see who is right behind me so I don't get hit.
Mirror extenders may work. You would need to source a reverse threaded bolt for the right mirror.
https://www.amazon.com/Motorcycle-Mi.../dp/B072XCTRZZ
https://www.ducati.org/forums/ducati...extenders.html
Pard is online now
post #162 of 180 (permalink) Old May 7th, 2019, 5:06 pm
gus duc's Avatar
Hey Pard & Firstascent...question for you.
When you installed your frame sliders was the OEM nut on the right side a 15mm? Also is the left side of the frame where the head of the engine bolt is kind of flat on the bottom?
I purchased the Ducato by Rizoma sliders and want to make sure they will fit before I open them. I know the suberframe is totally different but the main trellis frame looks the same to me.
Thanks!
gus duc is offline
post #163 of 180 (permalink) Old May 7th, 2019, 6:22 pm
Thanks!
The nut is 15mm and it is on the right side.
Not sure what you mean about the left side being flat.
Here is a picture of the OEM engine bolt assembly.
Name:	oem engine bolt.jpg
Pard is online now
post #164 of 180 (permalink) Old May 7th, 2019, 6:41 pm
gus duc's Avatar
Thanks Pard! Looks the same and the left side of the bolt has an 8mm Allen head. On my frame the left side hole is round inside & flat on the bottom of the outside. Here’s a pic.
Pard likes this.
gus duc is offline
post #165 of 180 (permalink) Old May 7th, 2019, 8:02 pm Thread Starter
Thanks! The reverse bolt should be no problem. I read the specs on the amazon link and it looks like the bolts that hold the estender to the bars are 10MM and the threaded hole for the mirror is 8mm so I need to check bolt size on the mirrors.
TexasJeff is offline
post #166 of 180 (permalink) Old May 7th, 2019, 9:36 pm
gus duc's Avatar
Mirrors are 10mm bolts that go into 10mm threaded holes on bar clamps. These will work perfect & come with the correct bolts for your holes & correct holes for your mirrors.
https://www.ebay.com/itm/10mm-Motorc...-/272110164589
Another option would be the Rizoma for Ducati Billet mirrors as the are more adjustable than your OEM mirrors & look nice but are about $150 a piece.
gus duc is offline
post #167 of 180 (permalink) Old May 7th, 2019, 9:41 pm
gus duc's Avatar
Here is the Rizoma with Ducati logo. You can also get it without the logo...Rizoma calls it the 4D mirror in their Universal fit series.
https://www.google.com/shopping/prod...780196159,cs:1
gus duc is offline
post #168 of 180 (permalink) Old May 8th, 2019, 5:47 am
The FAR mirrors provide the best rearward visibility of all the options I tried so far, no pun intended.
https://moto-science.com/products/co...left-7490-each
They can be mounted with the existing handguards and signals.
2019 Hypermotard Mods
The really cheap ebay bar end mirrors I tried may work for you as well, but their small size makes it hard to see behind without some effort, not great for quick target acquisition.
Pard is online now
post #169 of 180 (permalink) Old May 8th, 2019, 12:24 pm
gus duc's Avatar
Does anyone know if there are some larger, mirrors that install easily and "stick out further" on each side? I'm using this bike to deal with Austin traffic and I'm physically too large for the provided mirrors to see around me. I'm not worried if they are dorky looking. My concern is that when I have to make a quick stop I check my mirrors to see who is right behind me so I don't get hit. <img src="https://www.ducati.ms/forums/images/Ducati_ms_2015/smilies/tango_face_surprise.png" border="0" alt="" title="EEK! Surprise!" class="inlineimg" />
The FAR mirrors provide the best rearward visibility of all the options I tried so far, no pun intended. <img src="https://www.ducati.ms/forums/images/Ducati_ms_2015/smilies/tango_face_smile_big.png" border="0" alt="" title="Laugh" class="inlineimg" />
Actually those FAR mirrors with the OEM hanguards look like a poor fit as he has them ziptied together.
gus duc is offline
post #170 of 180 (permalink) Old May 8th, 2019, 1:13 pm
Good Eye! Did not notice that at all.
Pard is online now
1100s Hyper ecu map via TuneEcu dudz996 Tech Forum 3 Dec 30th, 2017 4:42 am
Hyper 939 SP impressions Say10 HyperMotard 19 Aug 29th, 2017 6:43 pm
Hyper and Hyper EVO? Satansfist HyperMotard 4 Jun 14th, 2017 7:45 pm
Help me love my Hyper 1100 sportclassicfan HyperMotard 4 Apr 25th, 2017 11:12 am
It's not a stereotype if it's always true... Hyper ClarkLife Ducati Motorcycle Chat 14 Mar 10th, 2017 11:29 pm
